メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2687回答 すべてを表示
Backlight broken after screen replacement. Soldered filter no fix.
Backlight doens't worker after change of screen
Tried changing cracked screen on my own. Did not turn turn off battery before starting.
Changed the screen. No picture. Used a flashlight and saw that the screen and phone was working, but with no backlight.
I sent the phone to a repair store in Norway. The guy said to me that I broke the backlight filter. He soldered a new one. Backlight still doesn't work. He says that he didn't find any other errors than the short-circuiting of the backlight filter. He has confirmed that it gets the voltage it should get.
He also said that the the backlight went on a couple of times when he tried booting the phone a second or two before turning off.
Do you know what the problem could be?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
From the sounds of it he didnt know too much of what he was doing or how to do it!
You can buy a backlight board from any good parts supplier. I personally wouldnt have soldered it as its close to the LCD and you dont want to damage that too.
What you need to do is disconnect the battery BEFORE anything else that you do.
I'd put a new screen on where the backlight is already fitted.
or
take it to somewhere else that has experience in changing screens.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jan Hansen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 332
