tail lights for my brake not working
2004 Mazda 6 my brake lights are not working.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
nanpage11 if you've checked all the bulbs and you found them okay, it is possible that your problem is the brake light switch. The switch is locate on the top of end of your brake pedal. Use a multimeter to see if it close when the brake pedal gets depressed and that it makes proper contact.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 7
過去 30 日: 17
今までの合計 1,788
