On/Off switched replaced but still not working
I have replaced the on/off switch on my Ipad but the volume up/down does not work, neither can the Ipad be switched off or on and I am not able to do a hard reset.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
You may have a defective replacement Power/Volume Flex. Finding good quality Small Parts is not always easy, especially if you buy them on eBay or Amazon.
I would also follow this guide to double check your work, you may have accidentally damaged the flex while installing it. Look at it carefully to see if there are any tears, even small ones.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 54
