How To Replace The Coax Antenna Connection Point
I opened a used iPhone that I want to fix and noticed that the antenna at the bottom right of the phone was not connected to anything and it seems that the connection point that the antenna clips onto on the actual phoneis broken. Is there anything I can do about the phone in order to fix that or if not, what can I do with my broken phone..
3 件のコメント
@drummerboy0109 post some high resolution images of your logicboard with your question. Use this guide iFixitでの質問に画像を追加する方法 for that. It will allow us to see what you see and hopefully can identify what is missing and what to do about that.
oldturkey03 さんによる
I posted a photo of what I need to replace. The tool is pointing to it and mine is broken
Jarred Ford さんによる
I found this post which may be useful to you. Can you repair the lower coaxial connector on iPhone 6 logic board?
BurnieG さんによる
