メインコンテンツにスキップ
Cannot boot after disk wipe
Help! I purchased a used Asus EP121 which the seller installed a non-activated version of Windows 10 on. After some research into drivers for 10, I decided to downgrade the tablet to Windows 8 and proceeded to wipe the disk, via an external optical drive using an old copy of Acronis True Image. All went smoothly, though I did foolishly allow the partitions to get wiped out along with the data, so not recovery partition anymore. When wipe was successful Acronis turned off the tablet. All normal. But when I hit the power button, the back-light flashes once then comes on, the optical drive (still holding the Acronis bootable dvd) spins up...but nothing else happens. Blank screen. So far I've tried restarting with and without power connected, with and without optical drive connected, with and without hitting ESC repeatedly, holding down Vol Down and power (this just caused the tablet to switch back off after a several seconds) and even tapping F9 (though without the recovery partition this is pointless), hit the tiny Reset switch between the USBs (which only works when running on battery only) and nothing seems to work. It won't boot from the optical drive and I can't get into Bios, or any other screens. Just back-lit blank black display. HELP! I just need this to boot from the external drive again so I can reload the operating system and make the tablet usable again. Can anyone help?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
BIOS? Press F2 after powering on to access the BIOS setup.
Funny Windows 10 not being activated as free when upgrading from Windows 7?
さんによる
コメントを追加
2件の回答
any chance you can grab the original version of windows thats suspposed to be on this computer?
the one from asus?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I've searched, but not found a source for a recovery DVD for this particular model. None that I trust (one website asks for $20 for the download but who knows what I'll be getting for my money). Not certain this would actually help, as I've also tried to use a standard Windows installer DVD and it spins up just like the Acronis DVD does, but does not boot either. I'm going to try an experiment using a bootable USB stick instead of the optical drive (once I've created it) but if that does not work then I have to conclude that something is blocking these external drives from booting up.
さんによる
コメントを追加
the acronis DVD may not actually be bootable. Try a bootable copy of windows OS to reinstall OS
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Greg Weaver さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 14
今までの合計 837
