My phone won't call anyone or accept any calls
My phone won't call anyone or accept any calls texting as well
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Chayala Berger first you want to make sure that you have service and a proper Sim card. Speak with your service provider. This does not sound like a hardware issue with your phone.
このアンサーは役に立ちましたか?
I had, this issue ....found out, because , phone had not been used , in a while .....network had , took number off .phoned up , network, and had it reset ....issue fixed .....just need to make sure I use phone more often ...
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,111
1件のコメント
Mostly restarting your phone solves the issue, temporarily. But repeated restarting is a semi solution... this happens to me semi regularly where I can't call out and have to restart... All I can think is: what if this was an emergency and I couldn't use my phone for 2-5min? $1300 phone should at least call out, always.
Maybe instead of asking for a solution I should ask what causes the issue?
Ember bb さんによる
