メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
add second sim card tray to galax s5 sm g906k
like in s5 duos? i mean nativly. so i can use 2 sim card simultaneously
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
Nintendo Switch 修理キット
ゲームを再開するための、早くて簡単な修理キット
Switch 修理キットページへ
Switch 修理キットページへ
1 件の回答
最も参考になった回答
No, you cannot.
The SIM tray is different. The internals of the phone are different.
The operating system is different.
この回答は役に立ちましたか?
スコア 1
コメント:
Well it seems that they are not that different. seems to be that on the non dual sim s5 only the connector socket is not soldered. the solder points are there.
of course also the middle frame is different which would be a problem to change out.
the firmware is different right but i guess that with a custom this also would be chnagbale. i guess i will start a thread at xda
s5 duos mainboard:
https://ae01.alicdn.com/kf/HTB11ihzLpXXX...
s5 mainboard:
https://ae01.alicdn.com/kf/HTB1RDjdKFXXX...
さんによる
@hanswurst31, are you sure both are using the same SoC (CPU chipset)? There are 2 versions, one with the Exynos, and one with the Snapdragon. Both ROMs are completely different.
さんによる
n o. the g906 uses a newer soc snapdragon 805. the pcbs are also not identical, but maybe compatible....
さんによる
@hanswurst31, there are different/more chips on one of the boards next to where the other SIM slot should be. I highly doubt compatibility.
さんによる
Don't bother (You will be wasting your time for nothing I'm warning you now), you will need to reprogram a second IMEI to the phone, modify the firmware, modem, cert, EFS file and lots more to get this working and yes expensive hardware and tools is required to do this.
I don't think this is even theoretically possible if you aren't a samsung engineer.
さんによる
コメントを追加
回答を追加する
Hans Wurst さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 7
今までの合計 92
