メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1778,1784。 GSM かCDMAの32、128、256GBがあり、色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラックがあり。
1268回答 すべてを表示
Now I'm one of those people
Did two handfuls, literally, of iPhone 7 and iPhone 7 plus. Had to do a warranty on a camera. Put the new camera on, and now the home button won't work! Yay! What else doesn't work? The camera! Tried two different displays and an oem one. Sometimes the home button works, most times not. I realize I'm supposed to be the resident iPhone expert, but I threw a bicycle pump across the shop after dealing with this. Any ideas? @mayer @oldturkey03 @refectio @pccheese @gigabit87898 @everybody else I forgot
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメント:
Try it without the camera you replaced.
さんによる
Isn't an iPhone 7 less than a year old, and hence still covered under Apple Warranty?
さんによる
So let me get this straight: You replaced the camera and the camera and home button don't work. Right?
さんによる
コメントを追加
1 件の回答
選択されたソリューション
When I run into frustrations like this, I have learned to walk away from it, go take a nap and let my mind clear. 50% of the time i will wake up and know the answer.
このアンサーは役に立ちましたか?
スコア 5
コメント:
better throwing a bike pump rather than the phone. I know ive had the urge to do so. A nap works too
さんによる
I told her 24 hours. Tried again this morning. One of the local shops advised me to just give her a refund, and get it out of my shop. Which I did. But I still want to know the answer! Which is difficult cause phone is gone now. Also my neighbor whom advised me said "yeah, we've had that. You can keep tinkering, or get rid of a gigantic headache" What I don't understand is the intermittent action...ya know now that I think about it, the button did work without the camera...
さんによる
Also the warranty on the camera, was an issue with the microphone/speaker. Think I hurt it while removing it
さんによる
A damaged / defective front camera assembly can cause the home button to stop working.
Especially if you plug it upside down while testing the front camera without installing it fully.
I guess the issue here right now is getting reliable replacement parts for the front camera assembly.
さんによる
Telling her 24 hrs was part of the problem. You put a deadline on yourself and additional pressure. I've done the same thing myself. You want to please the customer but it then ends up where you lose and the customer loses.
As Scotty on the Enterprises did, always tell them it is going to take twice as long as you think it is. Then when you finish in half the time, you're a genius instead of an incompetent out of work technician.
さんによる
6件以上のコメントを表示
コメントを追加
回答を追加する
iMedic さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 154
