CPU heats up - Don't boot-up again
1. Overheat CPU and turn-off my laptop
I understood something is wrong - because FAN isn't work.
FIX it
1.1. open Keypad
1.2. Separating the fan.
1.3. Clear board
1.4. Open FAN case
1.5. Separate "OK" label (Blue label on the FAN -It was stuck to the FAN)
1.6. Assemble laptop and Turn-on
(There was no reaction from the LCD)
(CPU FAN working very well - But the wind is cool) Is the CPU damaged?
2.open again and check connectors
- (Cable for battery)one cable is missed in the mainboard and no any symbol for positive and negative on the board for this cable .(Cable is dry from the heat, And separated from motherboard.) -laptop turn on Without batteries.
Is there a problem with this cable?
- I can't check CPU - because i don't have any manual, diagram or schematic for this main board and other accessories.
Does anyone have an opinion, idea or solution?
