メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
Popular laptop sold by HP. While it comes in many configurations, all models of this laptop have the same basic form factor. The numbers after G60 indicate the factory specifications of the laptop and who sold it.
50の回答 すべてを表示
How do I repair no sound
For some some time now I have not been hearing any sound on my G60 laptop. Can anyone please assist me with repairing the sound on my laptop. Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
iPhone LCDスクリーン修理キット
生涯保証付きの低コストオプション
キット商品を見る
品質ではなく、修理コストを削減しましょう。
キット商品を見る
4件の回答
最も参考になった回答
After trying all sorts of things suggested in Microsoft and HP troubleshooting steps, I came across an HP forum in which a problem of no sound after upgrading to Windows 8 or 10 from Windows 7 was presented. The cure was as follows and it worked for me tonight:
"If your notebook has 4 GB of memory, I know you are not going to believe this, but for some crazy reason having 4 GB of memory installed on that platform causes the sound not to work.
Try this workaround for that if your notebook has 4 GB of memory...
A problem with the Conexant audio means that you may hear no sound in Windows 10 even though everything appears to be working correctly.
Microsoft suggests running msconfig.exe and heading to the Boot tab. Click the Advanced options button, check the Maximum memory box and set the value to 3072."
If you don't know how to get to msconfig.exe, there are a variety of instructions on the internet. I just typed it into the Win10 search box. Not sure if Cortana lets you do that since I disabled mine. Make sure you reboot. You should hear the Windows theme play when you logon with your password. Tada!
I hope it works for you too.
Linda
この回答は役に立ちましたか?
スコア 1
コメント:
In fact, you don't have to drop down to 3072 ... just set it to 4095 and it fixed the problem!
https://h30434.www3.hp.com/t5/Notebook-A...
さんによる
コメントを追加
Did you recently upgrade your windows? Are all your drivers up to date? and a dumb question is your sound turned up? right click on the speaker icon and pull up the options ensure they are cranked up
この回答は役に立ちましたか?
スコア 0
コメント:
Hi thanks for your help. I ended up repairing it myself by going in to restore setting and reinstalling a driver I may have deleted by mistake.
さんによる
コメントを追加
You don't need to lose a whole GB of RAM.
You just have to give up one tiny little megabyte.
Works like a charm.
この回答は役に立ちましたか?
スコア 0
コメントを追加
Not true under System it says 4GB then says usable 3072 reducing by 1MB actually reduces 1GB
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Reesa Alexander さん、ありがとうございました!
統計データを表示:
過去 24時間: 9
過去 7 日: 53
過去 30 日: 128
今までの合計 667
