Both HDMI inputs no longer working
We had a thunderstorm roll through and the following day, I discovered that both HDMI inputs on my Panasonic TH-42PZ77U plasma TV, no longer work. The TV seems to be working fine otherwise (I can access menu, etc), but I can't get any image to appear regardless of device I plug in (Xbox360, cable box, Roku, etc).
Edited with photos showing boards. I don't personally see any damage but then again I'm not sure I'd know what to look for.
Edit: I tested with an antenna hooked up, and the TV does show antenna channels. HDMI 1 and 2 show nothing (blank), Component 1 & 2 same, and Video 1-3 show horizontal green lines.
この質問は役に立ちましたか?
3 件のコメント
Can you post a close up of the DG board?
oldturkey03 さんによる
The third photo I posted was supposed to be a close up of the dg board.. Is there a specific are of the board I should try to capture even closer?
Jon さんによる
Jon さんによる
