メインコンテンツにスキップ
Repair and disassembly guides for Mixers.
267回答 すべてを表示
Kenwood KH326 Multi One ticks when running.
I recently worked my Kenwood Multi One a bit too hard, and since then it ticks when I run it. I'm trying to remove the main panel, but I'm finding a bit of resistance. I know that there's a screw to remove, but I'm not sure if the blender driving sprocket needs to come off.
Has anybody done this?
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I had same problem with my Kitchen Aid stand mixer and after i took it apart i found a Vinyl gear (sprocket) in the gearing of the machine that is designed to break under to much load. Look into that.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ivan Aparicio さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 274
