My DVD will play but the picture is not clear and has blueish tinge.
There is no colour only a blueish tinge to the picture?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@evelfritz make sure that you try a different TV as well and try different inputs on your TV. This could be a bad DVD (try others) as well as a bad cable. Try others as well. If none of that works, you want to consider cleaning the laser. For that you buy a commercially available lend cleaning kit. If cleaning etc. does not help you may consider a bad laser assembly.
This should help to disassemble your 3_2_1 and test it. Let us know what you get. Bose 3_2_1 Disassembly and Test Procedure
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 61
1件のコメント
Thanks, I had forgotten they sell those. Will pick one up in the next couple of days.
Daphne Tarrant さんによる
