What is the rocker arm torque on a 1998 dodge dakota.
what is the rocker arm torque on a 1998 dodge dakota
この質問は役に立ちましたか?
この質問は役に立ちましたか?
ALEX STEVENS, You did not state which engine you have.1998 dodge Rocker Arm Assembly to Cylinder Head torque specs.
2.5L eng. Rocker Arm Assembly to Cylinder Head torque specs. 21ft/lbs., 28NM
3.9L eng. Rocker Arm Assembly to Cylinder Head torque specs 16.67ft/lbs.,22.6NM,
5.2L eng. Rocker Arm Assembly to Cylinder Head torque specs. 21ft/lbs., 28NM
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 18
今までの合計 3,517
