メインコンテンツにスキップ
Repair guides for Android cell phones manufactured by ALCATEL.
My mic doesn't work when my earbuds are plugged in
Whenever I plug in my earbuds my microphone doesn't work. I can hear the person I'm talking with but they can't hear me. Its worked a few times so I know that it can work.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 22
3 件のコメント
So does mine but i did everything for iT to
さんによる
Plz help me for my problem
さんによる
Same as me too please any solution to this please?🙏
さんによる
コメントを追加
13件の回答
最も参考になった回答
So my headphones work perfectly fine, except the mic. I can hear perfectly from the earbuds but whenever I make a video or call someone, all they hear is a buzzing sound. I don’t know how to fix it… does anyone know I i could
このアンサーは役に立ちましたか?
スコア 10
3 件のコメント:
exactly i have the same issue how did you resolve it?
さんによる
Try blowing in the mic. Could be blocked. Happened to me.
さんによる
In my phone ,the headphones icon shows but i can't connect the Bluetooth headphones in my phone they are working in background I can't hear any media sounds.plz any one help me
さんによる
コメントを追加
Do your earbuds have a built in microphone? If so try taking a video and seeing if the audio works that way. There is also a button you can press on the call screen that usually switches it from one microphone to the other. Also, make sure the headphones are plugged in all the way.
このアンサーは役に立ちましたか?
スコア 6
6 件のコメント:
My earbuds don't have a built in mic. I don't see anything on my call screen that gives me the option to switch mics.
さんによる
Does your headphone jack have 3 or 4 little sections on it? The little piece you plug into the phone, count how many rings are on it.
さんによる
It has three
さんによる
I have iPhone earbuds why won’t they work right now? I checked if they were plugged in.... they are! I checked if the wires were broke they’re not! WHATS WRONG WITH THEM?!?!?
さんによる
My earbud does have built in microphone, i just bought yesterday still my mic is not working, i have used 3, 4 earphones still not working, is the problem in my phone??
さんによる
1以上のコメントを表示
コメントを追加
So to start off with, at least you headphone jack is working and not stuck in headphone mode which can be a P.I.A. I know this is possible because I have a audio jack I take phone calls with with my car and people can hear me through one of the 3 microphones.
1. Let's test to make sure all of your microphones are working. Take two quick video and say test or something on both the front and rear camera. Playback and confirm you have sound.
2. If you haven't deleted it with the new IOS, go into voice memo and click the upper right corner of the screen with the sound icon, it's a little buggy since IOS 10 so toggle it from blue to white a couple of times to make sure its recording on your lower microphone and test the lower microphone by making a recording. If all three of your microphones work than we can go from there.
Let me know the results!
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I just tried that. When I record a video with my earbuds connected the mic works. But it still doesn't work when I make a call.
さんによる
I have a problem. My mic was working fine but when I plugged in my ear phones, the mic for the ear phones work but when I unplugged the earphones, my ipad’s Mic stopped working. I tested it by taking a video and the audio was fine. For some reason, no one can hear me from Facebook messenger, discord etc. can anyone help?
さんによる
コメントを追加
Ok. If you read my full post I have you test all 3 microphones without your headphones plugged it. Try all three and post the results.
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
OK I just did what you said without the earbuds being connected and all three recordings have sound- the mic picked up the sound in each setting. I tried each of the same three functions with my earbuds connected and only the video recordings picked up sound. Voice recording did not pick up the sound.
さんによる
Do you suggest anything else
さんによる
Any other suggestions?
さんによる
Help . I need more info
さんによる
My iphone has the same problem. did you find a solution?
さんによる
コメントを追加
I use my android headphones as my ps4 mic (EarBuds) the mic on the earbuds dosent work. I can hear my friends but They can’t hear me
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Try putting ur mic volume up
さんによる
So you might need a CTIA to OMTP converter. Basically for some reason some headphones have the ground and mic position switched and this fixes that.
さんによる
コメントを追加
When you plug in the headphones, you’ll get a pop up that gives you options. Make sure you select Headphone, not Headset. If you select Headset, you disable your internal microphone.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
How do you switch it from headphone to headset?
さんによる
コメントを追加
Ya something to do with the system like my headphones inside my phone system is not on how do I turn it on
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
maybe ur earphones are worthless or it broke
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
That's what I first thought, but when I plug them into my phone the mic on the earbuds works.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Well, I used to have the same problem over and over. First of all, you can try turning on your video because most audio works when the video is turned on. Second of all, you can try one of your three microphones. Most people’s devices have three different sources of audio connection that they can try. Third of all, there’s supposed to be this button on the earpiece, try pressing it once and see if it works. Fourth of all, try to increase the volume on your earphones with the little plus button, it also has a minus button to reduce. And last of all, just check if your earphones are plugged in properly and that none of the wires have issues. If any of these work, then you’re welcome, but if they don’t work, then I’m sorry, you should see a professional or just get new earphones!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Mine just had this problem, saw it was clogged of only god knows. I stuck a sewing needle in them to clean them, not sure that’s the best way but in the moment that’s all i could think of.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Like Nick I found lint in the audio, and lightning, ports. I recommend not using a metallic needle. I used a very small plastic zip tie which I made even slimmer and added barbs along the tip using a razor blade. That did a nice job of hooking the stuff packed in there.
さんによる
コメントを追加
please i need help figuring this out
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
So it is one of four most likely situations,
  1. Your microphone in your earphones are broken. This unfortunately can be quite difficult to fix unless your earphones have modular cables. But you might be able to fix it by cutting out the mic connection from where the mic is and connect it to ground.
  2. Your earphones have a 4 pole jack despite not having a microphone. This would probably be fixed by making one of the poles insulated, which is most likely the pole 2nd nearest to the cable
  3. Your headphones uses CTIA while your phone uses OMTP or vice versa. Adapters are sold which can fix that.
  4. Your phone does not support earphones without a mic and using only 3 poles properly. Nothing can really be done on the hardware side then unfortunately as that is a software issue.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Well, it can also just be lint stuck in the headphone jack where I'd say try using a plastic pick to clean it
さんによる
コメントを追加
回答を追加する
Isaiah Washington さん、ありがとうございました!
統計データ:
過去 24時間: 11
過去 7 日: 113
過去 30 日: 483
今までの合計 125,972
