How can I repair a door closer that doesn't damp any more?
Hi, I have a door closer GEZE TS 5000 and it stopped damping. Is there any way to repair it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi Guido,
There are multiple ways that your issue arises,
And thus there are multiple steps to fix this issue.
My first suggestion would be to see if the system can be tightened through conventional means. this can usually be done by tightening the screw on the side of the main enclosure (Usually on the right). It may be that you only have a disc with two holes for a tool, but turning that clockwise should tighten the spring. Another option is to see if the top bar can be adjusted, but I personally recommend against this action.
Please let me know if I can assist you further.
このアンサーは役に立ちましたか?
Hi,
I resolved the problem. The door was just closing too fast and slammed into its lock. With the right screw I could adjust the closing speed. In this instance it is the second screw from the right.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 17
今までの合計 2,112
