Lens says it's not attached properly
There's a message on my camera saying "cannot recognize lens attach lens properly" it's perfectly attached so I'm not sure what's wrong.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Your lens is probably damaged. Check the connections on the back of the lens . make sure they are not corroded
You may be able to clean the contacts with an eraser.
Good luck.
このアンサーは役に立ちましたか?
Wnen I said "damaged" what I really meant was, the contacts were likely dirty or corroded. My fix still works, but you can also use denatured alcohol and or Deoxit if they are really bad
過去 24時間: 0
過去 7 日: 4
過去 30 日: 21
今までの合計 1,030
