new key fob programing
How to program a new key for my Audi 2008 A3
Steps to reprogram keys to a car they are already linked to:
1. Press and hold the unlock key on a remote
2. Insert key in ignition and turn to on (while still holding unlock)
3. Hold unlock while in the on position for 2 seconds
4. Turn key to off, remove from ignition and release button.
Do this for each remote. Relink to seat positions (press and hold mem position #, then unlock button for 2 seconds and release both) and done.
To program new remotes on a car never linked to previously:
1. Take a key (valet key works best, put it into the ignition and turn the key to the "on" position, so the dashboard lights come on.
2. Roll down the driver's side window (not required, but a good idea in case there's a problem).
3. Exit the car and close the door.
4. With a second key, physically lock the doors by turning the key clockwise (don't use a remote).
5. Take the first remote to be programmed, press the unlock button. The lights will flash once.
6. Wait 10 seconds and press the unlock button. The doors should unlock. That first transmitter is now programmed.
If you have only one key skip to step 16. Otherwise continue to step 7.
7. Lock the door again (physically) with the key, (not the remote) by turning clockwise.
8. Press the unlock button two times with a one second interval in between, the lights will flash with each button press for a total of two flashes.
9. Wait 10 seconds and press the unlock button. The doors should unlock. The second transmitter is now programmed.
If you have three keys proceed to step 10. Otherwise skip to step 16.
10. Lock the door again (physically) with the key, (not the remote) by turning clockwise.
11. Press the unlock button three times with a one second interval in between, the lights will flash with each button press for a total of three flashes.
12. Wait 10 seconds and press the unlock button. The doors should unlock. The third transmitter is now programmed.
If you have four keys proceed to step 13. Otherwise skip to step 16.
13. Lock the door again (physically) with the key, (not the remote) by turning clockwise.
14. Press the unlock button four times with a one second interval in between, the lights will flash with each button press for a total of four flashes.
15. Wait 10 seconds and press the unlock button. The doors should unlock. The fourth transmitter is now programmed.
16. Remove the key from the ignition.
このアンサーは役に立ちましたか?
This doesn't work........
過去 24時間: 5
過去 7 日: 43
過去 30 日: 212
今までの合計 35,978
3 件のコメント
I'm trying to program a key for Audi A3 but, I don't know what I needed to do.. they tell to put a gecko id to program.. please help
=== Update (12/20/2017) ===
how to program a engine Audi...
what is a gecko Id for?? thank you
rene さんによる
audi 2008 a32tdi rhd dont work
kenneth mulford さんによる
audi 2008 2tdi rhd it dont work
