メインコンテンツにスキップ
本製品は、2010年7月27日にAppleから発売された解像度2650x1440ピクセルの27インチLEDディスプレイです。モデルナンバーはA1316。
78回答 すべてを表示
Is this worth fixing?
I'm looking to buy this cinema display, and I was wonder if you guys would know what was wrong with it. This is the description of the problem the owner provided
"Works perfectly EXCEPT it turns off after a half hour and must be disconnected and reconnected. This is a known failure that according to blog forums is due to the posterior cable that needs to be replaced. A repair shop quoted me $400 to replace it but a handy person could probably do it themselves. "
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
N T those questions are always really hard to answer. It will depend on if the description is right and forthcoming. You never know about who had their hands in those devices. You also need to know your own abilities. Ask yourself if you can fix it. Do you have the tools and the know how to get it done. yes their is always help available on here, but you are the one that will have to do the task. The other consideration you have to make is what it is going to cost you, repair and initial cost included. The only one that can answer this question will be you.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
N T さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 166
