メインコンテンツにスキップ
2014年10月5日に発売されたHDアクションカメラです。
79回答 すべてを表示
hero 4 most common component failure?
new Hero 4 black submerged in salt water for 7 minutes. After thoroughly rinsing with distilled water then drying the camera, I let it rest in rice for 5 days. Now it won't power up, make noise, or` give any indication of life left.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I had a GoPro Hero 4 Black sit at the bottom of the ocean for three days in a leaking waterproof case until a diver friend retrieved it for me.
Amazingly, I was able to get it to power on.
But I did the following first:
  • Dismantled the GoPro immediately and washed all components in isopropyl alcohol.
  • Ensure that all traces of corrosion (white) were washed off and that all metal contacts were clean
  • Let the components dry for several days
Now the GoPro didn't work 100% and required some parts to be replaced.
What worked:
  • WiFi
  • HDMI output
  • Lens & sensor
  • Power and WiFi/Setup buttons
What didn't work:
  • Some of the LEDs
  • The LCD display
  • The shutter button
  • The SD card expansion slot
  • The battery (it swelled and oozed)
Considering that your GoPro was only submerged for 7 minutes, chances are that yours is in better condition than mine was and so you may be able to salvage much of it and even possibly repair it to fully working order.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
davidendacott1 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 101
