Kickstand welded and will not budge
I have never seen a kickstand that was welded to the frame. Once down it will not return to the up position. I have no idea what to do.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@eddiem, Eddie, You may be able to lube(oil) the hinge/spring area of the kickstand to get it moving more freely if stuck. You are right, it is unusual for a kickstand to be welded to the frame of bike. If all else fails the kickstands weld may be able to be cut/ground off with a angle grinder and then stand can be replaced with a new one. If not comfortable/wanting to remove the stand your self perhaps pop into a local auto repair/autobody shop and have them remove the welded on stand for what I would think would be a small fee. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 672
2 件のコメント
Could you please take some nice pictures?
iFixitでの質問に画像を追加する方法
George A. さんによる
are you sure theres not some sort of safety clip to keep it from releasing when you don't want it to
Jimfixer さんによる
