メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号A1136/30、60、80GBハードドライブ/ブラックまたは白のプラスチックフロント
Very Low Battery, disk mode doesn't work
I recently took the front and back covers off my ipod to paint it. It was fully functional before this. Now, I get the very low battery screen. Holding select and play does absolutely nothing, and holding select and menu temporarily closes the screen. It is not being recognized by my computer, and the battery held a lot of charge a few days ago. Any other recommendations?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
Sounds like you've damaged the Battery. Try replacing it with a new one, and then post a video of your sweet new paint job
https://www.googleadservices.com/pagead/...
このアンサーは役に立ちましたか?
スコア 1
30 件のコメント:
Just ordered one, let's see if it works!
さんによる
I just replaced the battery. Now I have the whole loading screen to frowny face to low battery cycle going on...
My computer also doesn't recognize the ipod, the ipod won't go into disk mode or diagnostics mode.
さんによる
Dangit! Does it charge from the wall?
さんによる
Sadly, it does not charge from the wall.
さんによる
I've never worked on one. I'm trying to figure out how easy replacing the dock connector is. If it's soldered on, maybe not so easy for someone who does usually do those repairs...
さんによる
25件以上のコメントを表示
コメントを追加
最も参考になった回答
@treeofeden careful with the battery connector on this model.It has the tendency to break of the board. It is very common and you need to check this based on the very low battery screen
このアンサーは役に立ちましたか?
スコア 4
6 件のコメント:
I just posted some pictures of mine, it doesn't appear broken.
さんによる
That looks good so hopefully @theimedic is spot on with his answer. Glad you checked.
さんによる
I hope so too @oldturkey03 not a lot of people work on iPod. Trying to erase the Apple ID on one right now...
さんによる
Also I've broken off battery connectors before. They go right back on with a little solder
さんによる
@theimedic I really like the 5th and 6th gen iPod but love the sound from my 3rd gen . Problem with the 5th and 6th gen is the battery connector. When you have to move the clip straight up there just is not enough room. If you follow the ifixit guide and use a plastic opening tool, your chances of breaking the connector of, is incredibly high. I always use a small paper clip that I bend into and L-shape. It allows me to hook it under the latch and pull straight up. Yes, relatively straight forward fix unless the traces rip off as well :-)
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Harris Edenbaum さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 28
今までの合計 1,893
