メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
Booting up is slow
My iPhone 5S boots up very slowly sometimes.
When on the Apple logo, he stays there for some time. Sometimes he starts up normally, sometimes very slow.
I also noticed that sometimes when on Apple logo he will reboot and start booting again.
Weird, because sometimes everything goes normal, sometimes he starts up slow.
I checked battery health via iBackupBot and battery still have 90% of original capacity.
DFU restore has already been done..
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Apple quietly changed the file system in iOS 10.3, it may be that the file system on your iPhone is corrupt.
I would suggest the following:
• backup your iphone completely in iTunes
• grab the latest full iOS update from http://www.iclarified.com/750/where-to-d...
• put your phone into DFU mode
• in iTunes, it will ask to restore -- in Windows hold shift and click Restore and select the firmware you just downloaded; in OS X hold Option and click the restore button and select the firmware you just downloaded
• after the firmware finishes restoring to the iPhone, it will as you to restore from a backup -- don't -- instead, set up as a new iPhone and follow the iphone through the new set up sequence
• now, restore as from the backup you made in the first step.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Didn't help. Problem was also there before iOS 10.3.
Thanks though. I apreciate your answer ;)
Sometimes he boots up normally, sometimes he's slow.
さんによる
Just curious, do you have like 100 apps installed, user data / internal storage filled up?
さんによる
Not actually. Even when fresh from regular restor or DFU restore it happens.
さんによる
コメントを追加
回答を追加する
Didier Daniel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 914
