How to disassemble the back
How to disassemble and access the battery
この質問は役に立ちましたか?
From what I remember this model open from the front. You need to remove the front glass and LCD. Which is attached to the frame, which is clipped into the back.
Very annoying repair, and risky. You need to be careful while removing the LCD and mid-frame, as it's easy to crack the LCD while you're prying.
Once the screen and frame are removed, the battery and motherboard are located right behind it. You can remove the battery and replace with new one.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 250
