Battery not detected and auto turn on
Good morning,
I was trying to get a working MacBook Pro from two different, not working entirely. I will try to explain everything as better as I can.
One of the two did work perfectly, the problems where a completely broken screen, broken trackpad and very ruined casing.
The other one was my original one, which had a long series of problem. Everything started with a hard-disk problem, apparently according to the mac partition it wasn't working anymore. So, since with the Windows partition everything was working fine, I resetted everything and reinstalled Mac OS. After that things seems to go well, but at some point the Wi-Fi stopped working suddenly. So I bought a new wi-fi card from ebay, installed it, and started using the mac again. Now the wifi was going perfectly, but a new problem arised. The battery was not detected anymore. I then brought my mac to the apple store to check for the problem and they told me after some struggling that probably the mainboard had to be replaced for some unknown reason.
I then tried to fuse those two macs into one, by changing my motherboard. And then the same problem as before arose also with this new one. Battery was not detected and now also wifi was not working.
In detail I have the following problems:
-> The battery is not detected, it's like no battery is connected to the mainboard. MagSafe adapter show always green light and without it, it doesn't turn on.
-> As I connect the MagSafe to the turned off mac it automatically turns on!
-> Wifi is completely not working, as if I have nothing connected to the mainboard.
What I already tried:
-> SMC and PRAM reset. (SMC probably can't be completed in the right way, because of the auto-turning)
-> Tried another battery.
-> Tried another MagSafe. (Now I'm using one of a 15'' MacBook Pro)
-> Starting with the completely connected Motherboard I started to detach every device from it, until I got to having only Fan connected, to see if some device was causing the auto turn on.
Anyone have any suggestion of what is happening to my motherboards? (I forgot to mention that both behave the same way, auto-turn on without any device connected)
Thank you very much!!
この質問は役に立ちましたか?
