メインコンテンツにスキップ
2016年3月に発売された4インチのiPhone。ハードウェア仕様は6sに類似しています。シルバー、スペースグレイ、ゴールド、ローズゴールドのカラーが揃っています。16/64 GB容量、Model A1662とA1723
1049回答 すべてを表示
Vibrator runs continuously after rebuild
My iPhone se had broken screen and damaged housing but worked ok. Bought new housing and transferred whole phone (as I have done on numerous occasions). On startup vibrator starts with Apple logo and runs continuously.
I have restored phone and replaced power cable. No change. Tried different vibrator motor too.
Any ideas?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
5件の回答
ベストアンサー
I would suspect a damaged flex (look for a micro tear, probably on the edge) or FPC connector. Go back through this guide.
iPhone 5s Audio Control and Power Button Cableの画像
製品
$14.99
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
That's what I thought but problem persists after replacing power button cable with new
さんによる
Did you check the connector on the logic board and its surrounding area. The connector may have been damaged or some small parts may have been pried from the board when lifting the connectors.
さんによる
Hi yes. I got a technician friend to inspect. He said he removed a small metal "swarf" and I thought that would be it - but no!!
さんによる
コメントを追加
最も参考になった回答
Exact same situation here: after a rebuild, it kept vibrating as long as tension was there (at startup, and when screen is on - and a little while after). I followed Eduards Blumbergs advices : I've reset this metal pin to its initial position (I suppose it's meant to be parallel), no result.
Then, with the phone powered on and opened, I tried to unscrew a bit the bridge-looking metal piece which links the vibrator to the other contact, and the vibrator stopped totally. I tightened it back, and it went crazy again.
Then, I unscrewed a bit only the top left screw, the one on the vibrator, until it stops, put my phone on silent mode, and with another phone, I call my iPhone SE, and it vibrated only when needed!
I guess too much pressure on it was forcing the contact on the power bracket under it.
Thanks for all your input, glad I found this thread, which is a lot more accurate and technical than all other google results (“my phone fell in water and keeps vibrating, help”)
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
You sir, saved my day! Thank you! I've been changing the case for the first time and worked on it for 4 hours only to then face this problem. Unscrewed a litte while phone was running and it's working fine now! :)
さんによる
The motor has two contact legs at the bottom with an insulation pad glued to the housing which went bad i guess. A piece of tape fixed it.
さんによる
コメントを追加
Make sure that metal pin that is attached to display assembly is not bent, so it can not touch the vibromotor properly.
Also check for small pieces, dust and likewise in the connectors and interior of the phone. Clean with lint free q tip or small brush with rubbing alcohol and let it all dry. Also check all screws of the phone interior (also socket screws), if they are not tightened too much! Check if phone is not bent - if so, unscrew the motherboard, straighten it by wooden pieces and C-clamp.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
This is an old post, but wanted to know did this ever got resolved or has this happened to anyone else?
Excactly the same thing happened to me today.
After rebuild when the phone is powered on the vibrator starts and does not stop until the phone is off.
I used housing with small parts included so might be the power-flex. Did not have time to try another power-flex. All the buttons work fine otherwise.
PS. There is lots of posts on the Apple forum this happening out of the blue without touching the hardware.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
I have had the exact same problem. I transferred my iphone SE internals into the new housing. The housing came with small parts included, such as flex cables, head phone jack, vibrator, etc... Build went smooth, but at start up the vibrator wont stop. Even when the phones off, the vibratory will run for a second when i click the sleep/wake button. I know these are old post, but have these issues ever been resolved?
さんによる
I suspect damaged flex if so! :(
さんによる
I took out the vibrator supporting metal piece out and it works as expected. Guess some short happening when the metal support is placed
さんによる
コメントを追加
I know it is a fairly old thread, but I am still using (and loving) my old SE 2016, so maybe this could help someone else as well.
Yesterday I replaced the flex cable, as my power button was not working. After assembling the phone the vibrator motor went on non stop like crazy.
After some time I figured out there was a short somewhere and I was measuring 3v on the grounding point just by the vibrator.
I have simply covered the contact points from under and over with insulation tape and that did the job.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
rob.crame さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 12
今までの合計 1,216
