MacBook is overheating from idle to regular use
My macbook is at around 60 - 62 degrees Celsius at light use like web browsing and watching videos and the fan runs at the default 2000 rpm. Both the upper and lower body get uncomfortably warm to an extent that I can't touch it. Do I need to replace the fans or the heatsink?
Update (05/24/2017)
These are the stats for 20% CPU usage but the laptop is uncomfortably warm.....correction hot at the top and I can hardly touch the bottom!
It's super hot around the processor and the heatsink at the bottom and the whole top is quite warm.
The stats:
- fan: 4945 rpm
- ambient: 52 degrees
- battery max: 43 degrees
- CPU core 1: 74 degrees
- CPU core 2: 71 degrees
- CPU PECI: 74.1 degrees
- CPU proximity: 63.5 degrees
- GPU PECI: 69 degrees
- heatsink proximity: 53.6 degrees
- memory proximity: 53.1 degrees
- memory slot: 57.1 degrees
- palm rest: 41.1 degrees
- pct die: 73 degrees
- hdd: 46 degrees
Apps open in the background/everything minimized/ max cpu usage 20%:
- Safari (had no web pages open)
- contacts
- notes
- calendar
- reminders
- maps
- messages
- facetime
- iTunes
- iBooks
- app store
And when i closed all the apps without shutting down the CPU temp remained the same but the fan came down to 2000 RPM
2 件のコメント
If the fans are spinning, I don't see a need to replace them.
The heat sink either, unless it is broken from a hard drop.
On the other hand, CPU compound is a good idea.
But what happened to cause this? After an update? A hardware upgrade? A previous repair? Some liquid damage? If you're not sure about liquid damage, or you think it never happened, open it up and look at the board specially around the edges near the LCD connector and where the USB ports are. Those are the places most commonly damaged by liquid. Disconnect the battery before touching anything and preferably don't touch anything on that board either way. Just observe and report back with your findings - if any, and pictures.
Rany さんによる
Im not really sure. At first I thought it was the magsafe dc port as some of the connectors looked black, kinda burnt. But i changed it and also the thermal compound along the way. But still it gets quite warm.
Not sure about liquid damage though.
yousuf-bilal1 さんによる
