Appleの iPhone 5sは2013年9月10日に発表されました。このデバイスの修理は全モデルの修理と類似しています。そしてスクリュードライバー、こじ開けツールが必要です。GSM か CDMA、16か32、64GBがあり、色はシルバー、ゴールド、スプレーグレイが選べます。
3853の回答 すべて表示
Why my jack play only one earphone after replacing the lightning port?
Hi
I have problem with my Iphone 5s. After lightning connector replacement (iPhone 5sのLightningコネクターの交換) I completly lose sound in one of earphone on any earphones that I connected and I don't know what is the reason for this. When I tried connect "old-damaged" module of lightning with old jack socked, the problem is same.
Do you know what is wrong with it? How can I fix it?
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
My guess is an issue in the audio circuit on logic board which requires diagnosing via schematics and microsoldering.
Otherwise physically damaged charging port connector.
による
Do the earphones work fine on another device?
による
Yes, it works great with anther devices
による
have to tried both headphone types, 1/8 inch and lightning connectors?
による
No, because I don't have headphone with lightning connectior. Anyway I would like to use standard jack as it is in Iphone 5s. I use my own headphones Sennheiser (not Apple product)
による
表示する 1 他のコメントを
コメントを追加
MacBook Battery 修理キット
最低価格 $69.99
Buy Now
最低価格 $69.99
Buy Now
3回答
選択されたソリューション
That's what I'm thinking. You need to test a different pair of headphones, to rule that out. If the problem continues to persist, get your new Lightning dock exchanged. If that continues, then likely the Qualcomm. Which is not an easy repair, unless you have all the equipment and the experience to use it
iPhone 5s Lightning Connector and Headphone Jack
This is how to contact iFixit for an exchange
http://help.ifixit.com/article/136-email...
iPhone 5s Lightning Connector and Headphone Jack画像
製品
$29.99
この回答は役に立ちましたか?
スコア 6
コメント:
Thank you very much for your response iMedic! As I said, I tried connect old iPhone 5s Lightning Connector with damaged charging port and working jack and problem doesn't disappear, but I think about new connector to test it for sure! Im going to buy new one and check it out. I will let you know what is the result.
による
Ok, today I ordered new one part and Im waiting for delivery. Keep your fingers crossed :) Estimated delivery time: friday
による
Why didn't you test another pair of headphones before purchasing this part?
による
I tried to connect another headphones and problem is same
による
Ok. Then we move onto testing a known good Lightning dock. One you know for certain is 100% working
による
コメントを追加
Maybe there is simpler solution for my issue?
この回答は役に立ちましたか?
スコア 0
コメント:
did you try your phone with a different headphones?
による
Yeah, dude. We've both told you a couple times, to test new headphones to rule out the headphones being the problem
による
コメントを追加
I don't understand it at all! After replacement part (twice!) is same and now I have not vibration and + volume button doesn't work :( (I didn't touch them!)
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Bartłomiej Jakubczak さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 101
