メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2038回答 すべてを表示
My iPhone 7 will not stay on
Hello,
About a month into having a brand new iPhone 7 i had dropped it an cracked the screen a little. When I'm using it the part where the screen is broken lights up differently. You can tell something is wrong. I went a few months like that and ended up dropping it again. Days went by and my phone would turn off around 40% then 60% and now it won't stay on for more then 10 seconds without being on the charger. It doesn't have the powering off spinning circle when it turns off it goes completely black. I don't know if i should replace the screen or if its something else. I don't wanna spend unnecessary money on the wrong things. please help. Is it the LCD cord detaching or is it my battery??? I'm so clueless. Also if the top left side of phone it looks like its coming up a bit.
another thing is iv only had this phone for 6 months.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメント:
I hope you mean LCD Cord...
さんによる
lol yes idk why i even put LSD I'm such a dummy sometimes
さんによる
コメントを追加
3件の回答
選択されたソリューション
Battery needs replacing and the display is recommended to be replaced as you will need to lift up the screen to get to the battery.
I recommend getting it repaired by apple (Approx $129 USD so it's a no brainer) as the good replacement screens are quite expensive.
このアンサーは役に立ちましたか?
スコア 3
コメント:
would you know how expensive it would be if i took it to apple?
さんによる
My guess would be around $349 USD.
さんによる
Last I checked iPhone 7 plus repairs at Apple are $140? Gonna go there in the next couple days. I'll ask. I'm thinking the damaged display is now over drawing the current from the battery
さんによる
I was basing prices off the original replacement screen price online.
It's probably cheaper from apple store.
Apple website says $129 USD that's good and cheap.
さんによる
thank you i will take it in today
さんによる
コメントを追加
最も参考になった回答
It is probably the Screen Assembly. If it is flickering and not functioning properly, that is a strong indicator of LCD Malfunction. However, from the issues you describe, it could also be the battery, or even a combination of the 2.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Maybe the LCD start giving up. You should replace the LCD first, if issue dont go away then check the battery.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
sabrina さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 3,000
