メインコンテンツにスキップ
モデル番号A1502 / 2.4, 2.6, 2.8 GHz デュアルコアIntelプロセッサ/ 2013年10月発売
552回答 すべてを表示
a1502 dead logic board
Hello Guys
Macbook Pro Retina A1502
COMPLETELY DEAD
No water damage, it simply didn't turn on again.
MagSafe is working normally.
However I think I should go over the power rails to fix this BOARD, right?
Is there anyone that can me give the next steps here?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Find power aliass on your schematic, start testing power rails, I would start with pp3v3_g3h. You will want to use process of elimination, by that I mean find what power rails you have and what are missing, then work your way backwards to find the source of the issue. Remember when testing rails don't go from A to Z, start with point A then test point Z , then point B then point y and so on till you find the issue.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
@triomacrepair
Still looking for your answer about REMOTE logic board repair tutoring.
Anyways.
I will go A to Z, cause at NOW my mind cannot understand why go to Z if B, C or D can give me the wrong voltage for example.
I mean, by logic, if B is an ISSUE the rest of the BOARD will be giving me wrong values. I guess so!
Forza if possible reach me by WhatsApp +55 53 9 9705 9883
Thanks!
さんによる
コメントを追加
回答を追加する
Angelo Recaman さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 594
