I change the spark plug, air filter and fuel filter stil do not start
I put a new tune up kit for my echo srm 225 still not start
How old is the trimmer? I have seen the fuel lines go bad over time and have a pin hole in it that causes issues with the fuel feed.
このアンサーは役に立ちましたか?
It's usually a pin hole in a fuel line, primer bulb, and sometimes there is one in the diaphragm. It could also be a bummer up carb. Try cleaning it through the filter housing with carb cleaner.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 478
