メインコンテンツにスキップ
Valve Steam Controller, released November 10th 2015. Model 1001.
16回答 すべてを表示
One of my triggers works ok but got squishy
My steam controller left trigger works when you pull it but doesn't have that 2 stage feel to it. It's as though the piece stopping the trigger just before the 2nd stage is gone and it just squishes into the button. I like the controller and I want to fix it instead of buying a new one. Is there some kind of trigger replacement possible?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
you would be looking at a full logic board replacement. The haptic sensation from the second-stage push-down on the trigger occurs when the trigger assembly places pressure (from your finger) on an embedded metal tensile pad which will click when enough force is applied to it. There's no feasible way of removing and replacing the sensor as it's metal appendages are folded into the PCB board.
Your best bet would be to leave the warranty stickers (covering the three internal PCB screws) in tact and contacting steam customer service, otherwise you're probably looking at a new piece of hardware.
rip.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mark Wright さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 130
