メインコンテンツにスキップ
Huawei Watch battery requires calibration?
Hello all,
I bought this watch recently, and I noticed that after fully charging the watch, it will drain quite fast (8-12hrs) to 1%, and then holds on this 1% for up to 24hrs more.
This is limiting my experience on it, despite OK overall battery life, because at 15% the watch will activate battery saving mode. So I'm stuck on this mode for like 30 hours of the total battery life span.
I tried resetting the watch multiple times, and I also updated to Wear 2.0 but still the same behaviour.
Is that a known issue with this watch? Is there a way to re-calibrate it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
http://m.huawei.com/kw-enmobile/consumer...
That might help you calibrate the battery, it for a phone but its worth a shot.
Hope this helps! If it did please hit the accept answer button!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Well, this seems to not help, because the watch will turn on automatically when put on the charger so you can't actually charge it while off.
さんによる
コメントを追加
回答を追加する
Omar Qatr さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,000
