メインコンテンツにスキップ
TV Won't Turn On
The TV will not turn on, neither the remote nor the button on the TV will get it to turn on. However, there is a small red light on near the power button, so I believe the power supply is working.
Prior to this the screen had a few horizontal multicolored stripes of dead pixels, and the TV would occasionally turn off with a click, and randomly turn back on again.
Is it fixable?
Thanks!
Edit: I know Samsung TVs and other electronics had a problem with capacitors failing, and according to the model code the TV was manufactured in 2008. Could failed capacitors be causing this problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
Hi Jacob.
Bad capacitors could very well be the problem.
Probably the most common issue with TV's, and not just Samsung. (They just had the biggest shitstorm) Also LG, Sony and so on.
I would go for this, as a first attempt of trying to fix the issue.
If you know your way around the basic electronics, you should go look for bad capacitors, most likely on the PSU board.
Remember to check the ESR (internal resistance) of the capacitor, not just the value i Farads.
Best Anders
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks for the information, when I get time I'll take a look at the boards in the TV
さんによる
コメントを追加
There are class action law suits against Samsung on this well known issue, sometimes they will send a tech out for a free repair:
https://www.cnet.com/news/samsung-power-...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I too had a very similar problem with a 49" Samsung TV. After opening it, found there were 2 blown caps. Went to local electronic store, grabbed a soldering iron and replacement caps that matched, and after replacing them, TV was back up and running.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jacob Micallef さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 1,582
