Can't get my machine to prime
I haven't used the machine that often, the last time I tried to prime it the motor goes but does not draw up the water, maybe an air pocket in the line?
You can use a turkey baster/ear bulb/etc to force-prime the pump; often they get airlocked when sitting for a long time. Fill the bulb with water and fit it into the water intake hose, then with the pump running squeeze the bulb to force the water in. As soon as the water starts to flow easily turn the pump off, put the hose back into the water tank and continue priming.
このアンサーは役に立ちましたか?
Mine had been in storage for 3 years. I used the bulb filled with water to get my pump primed.
Thanks Henry !
Eureeka! Everyone in the family tried in vain to fix this machine, with no luck. I had it boxed up last Christmas to send to Vancouver repair person and just yesterday 10/28/2013 I researched again - bought a $.99 suction bulb and it worked!! Thank you!!!
Opening the steam wand did not work for me; and I was not able to force water into the pump hoses from the exterior. I had to disassemble the bottom (in my case only 4 screws) to access the water tubes. Then using a basting syringe I forced water into both tubes and because I had heated the unit before I could hear the water hit the hot tank inside. I reassembled and made a great cappuccino!
the bulb worked! i forced water up the hose and now it's working again! thanks...one problem though...water isn't that hot :O(
It worked! Yippee! I surely thought it was broken.....good friend gave me her old machine and it had been sitting for about a year and it flushed it with a tiny syringe and its working great now! Thanks!
Guys and Gals, just follow the directions given by Starbucks: the approved and simple method for priming the pump dies not require turkey basters or ANY tools. Turn the machine on but leave brew and steam switches on right OFF. Place a cup under the steaming wand. Open t he steaming valve. Now, although we did not heat the boiler for steam, the wand has this second function, namely priming the pump. When the valve is opened but the boiler is not heated for steaming, the pump kicks on and primes the pump. When the water from the wand is flowing in a continuous stream (3-5 seconds), shut the steam valve. You may now heat the water to steam or brew.
このアンサーは役に立ちましたか?
Yes, this is the correct procedure to follow when the machine is new or has had it's boiler otherwise purposefully emptied. However, when the machine has sat unused for a long time the pump can become dry-locked and then it requires either water under pressure (via a turkey baster or similar tool) or compressed air to be forced through it to began working properly again.
Mine sat for 5 yrs, pulled it out to use it and had no prime. The pump worked, and i took everything apart including the one way valve on the pump, reassembled and still had no prime. I used this method above and it worked perfect.
My machine is over 7 years old and I accidentally ran the tank out of water and needed to reprime the pump. I followed these instructions and the pump was primed and is working well again.
I tried priming the pump using a turkey baster but could not prime the pump. I will use the steamer from now on. Great machine and very simple to operate. Hope to get 7 more years out of it.
This worked for me. Thank you! (I'd left the machine running for 5 minutes with no water in the tank and couldn't get it to pump afterward until I tried this.)
Thanks anami!!! spent an hour trying the baster thing and nothing. finally found your answer and worked in less than a minute! Muchas gracias, now my co-workers in the VA can try Cuban coffee for the first time!
I found that if the machine has sat for a while (years in my case) just using the steam wand WILL NOT WORK. I followed the suggestion of forcing water into the pick up tube that sucks out of the water tank. I used one of those injectors (like a big hypodermic) for flavoring meat. Worked right away and I’m pulling pretty good shots already. Good thing since my Rancilio Sylvia just bit the dust after 20+ years. Got the Starbucks machine a long time ago at a thrift store for $50.00. Oh did I mention it was virtually brand new? Thank you IFIXIT people!
このアンサーは役に立ちましたか?
Works with Graef ES. I've usually had to wait an hour or more when it's accidentally run dry. This time I was up and running only a few minutes later. First time I've used the steam tube.
このアンサーは役に立ちましたか?
Hello! I hope i can post a question.. So mine won't prime either but it is making a loud humming clanking sound when I turn the wand to prime... Will turkey baster work for my unit or do I have a broken part?
このアンサーは役に立ちましたか?
Janet, if your machine has a descale light then it isn't the machine being discussed here, and I'm afraid most of the advice won't apply.
What if you go though this bulb manual priming method and it won’t hold a prime more than three days? Bad pump seal? Replace the pump?
I’ve used both the manufacturer’s priming method (steam wand when machine is cold) AND the turkey baster method with no luck. Compressed air? Help! Bought this (used) for a friend and the owner said he used it successfully 6 months ago!
このアンサーは役に立ちましたか?
I have the same problem!! WhT now??
My steam wand works and steams milk. Why won’t it pull a shot?
I read through this on other forums to try to understand this problem. Apparently there is a tiny ball of plastic that serves as a switch between the steamer and the espresso feed. When the machine is sitting for a long time, that can become stuck in the last position it was used. I thought it might be possible to use vinegar to unstick the ball, so I put vinegar water in the holding tank, ran some water through the steamer so there was vinegar in the junction chamber and let it sit. When I tried it a week later it worked flawlessly.
Baster did not work for me. I needed remove the cover and elevate the syphon tube above the pump. Removed the filter and filled the tube with water and massaged the tube to release air bubbles from the pump. Filled the tube twice. When massaging, squeeze as much of the tube as you can to create enough suction to draught out air bubbles. I used at least six fingers.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 6
今までの合計 3,080
