メインコンテンツにスキップ
Charging port won't charge batteries
I plug in the mod to the charger and it won't charge the batteries. I think it's the charging piece, but I don't know what to do.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 10
18 件のコメント
Mine is doing the same thing I've switched the batteries around and eveb tried a different charger and it won't charge.. I just got it not eveb teo weeks ago so I'm highly upset
さんによる
Even* two* sorry was typing to fast
さんによる
I got mine today and its doing it
さんによる
Think u have a bad device had mine 6 months it worked great it's bad now I'm having to charge my batteries externally because the charge port on my device seems to have come out of the device am annoyed with that
さんによる
I have had my smoke procolor for 2 days and it will not charge! I am highly !#^&@@ off!
さんによる
13件以上のコメントを表示
コメントを追加
15件の回答
最も参考になった回答
I just got the Alien mod yesterday and can't charge on my wall plug block either. I have been reading everything I can find and I think the answer is actually simple. You just aren't getting enough power through the wall block. Example is as follows:
Wall block output on mine = 1 volt at a max of 1 amp.
Standard USB port = 5 volt at a max of 1.5 amps
My batteries are 3.7 volts at a max of 35 amps. 1 volt is so low that it just won't power the battery. I would suggest going to your local dollar store and buy a wall plug that puts out a minimum of 3 volts, 1000ma. Should cost you about $1 plus tax and they usually keep them at the cash register or in the cables section depending on the size of the store.
このアンサーは役に立ちましたか?
スコア 6
3 件のコメント:
Just an update. I have tried this now and The problem is solved. My block was so under powered that it actually fried trying to charge the Alien. I went to Best Buy and got a good Belkin one for 13.99 and it charged from absolute zero to 100% in 4.5 hours. Vape on it for a full day and still had about 55% battery power left.
:) Smiles for everybody! Jordan
さんによる
This worked!!!! Husband was freaking out couldn’t vape for 4 hours!!!! Look at the block and the volts!!!!
さんによる
I had two of them Alien mods and both of them the metal piece, that u plug charge cable in, fell out
さんによる
コメントを追加
Get an external charger. Although it won't fix the port, but at least you will be able to vape. Get extra batteries too.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
I was having the same problem of my batteries not fully charging. Well I have just tested an idea. When the alien times out it quits charging but if you light up the screen again it starts charging again. My batteries have went from 50% to 73% I now have them up to 96% but I have to keep turning it BK on. So I changed my screen time to a longer time and it charges longer. So you might try that. It is working for me.
さんによる
I think that may be it just updating the battery volume from the last time the screen was lit. I have 2 aliens and a smok gpriv that does the same thing
さんによる
@danastrader I tried your idea and it works. Seems the screen with the A and B batteries is just a lock screen or something. I changed my screen time to 220sec and the batteries are now charging. Just need to click to get out of timeout screen in order for charging to start back up Thanks!!!
さんによる
コメントを追加
Anyone else having this issue and the above solutions aren't working (besides the external charger of course which is the only easy fix) here is some info for reference. The charge port itself is soldered on the backside of the mother board and comes through a hole in the mother board and requires microsoldering to fix or replace the charge port, also covers are also lightly soldered onto the motherboard easily break if moved around. I added photos for reference (charge port cover has already been broken off in close up pics). Sorry since it's not really a solution
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Mine just won't charge on the charger I have it plugged into a multi outlet center but everything else works just it's not charging
さんによる
コメントを追加
Your are not supposed to charge the alien through the USB port, the port should be used for firmware updates only. You need a external battery charger made for lithium batteries nite core and efest make inexpensive but reliable chargers. Charging any mod through the usb that takes more than 1 battery is dangerous.
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
My Smok Qt box won't charge it's staying on 0% and will turn on but no charge says low battery and if I unplug it completely turns off
さんによる
Mine just started to say that on!y one battery is charged when I do use a charged and have back up batteries. I don't understand y this is happening. Oh I have a smoke 220 and this is the second one that I have bought.guess what not again will I buy one. Does anyone know what I can do about this?
さんによる
I bought myself an external charger as suggested but is still not charging the batteries. It shows the EE sign and not charging. What now?
さんによる
have the same problem; one battery 100% the other 0% placed other batteries same problem. It's a piece of junk lasted 2 days; bought it on eBay so I should get my money back and maybe the mod because seller not responding. This is the third mod that didn'the last more than a week the smaller built in battery mod last longer but once the battery dies it goes to the trash except the tank.
さんによる
My vape has been dead for over 2 weeks how long do I have to leave it plugged up before it shows me that it's charging
さんによる
コメントを追加
I don't believe the micro USB on the alien supports charging dual 18650 batteries. Voltage is too small, the port provides ability to update the software only.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Will it tell you if it's charging
さんによる
Why in the world would the designers of the firmware waste their time creating not one but TWO animations indicating that the installed batteries are charging (thru USB, no other way for electrons to find their way to the batteries.) ???
While on the topic of firmware, however, I feel like I should point out to everyone in this thread that unauthorized Chinese clones ABOUND on the intertubes. Some are extremely convincing, and you will only know when you try to scan the QR code which Smok requires in order to authenticate for support services. My device is a clone, and I've been using it for a year, but results will vary.
Cheers.
さんによる
コメントを追加
What is the model name and number?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Got mine today, I have the prince stick mod, it charges for about 10-15 seconds then stops, i haven’t even hit it once, I’ve tried to plug the charger into many different outlets but nothing works I spend almost $50 dollars, and had to buy another one online but still does the same thing, what do I do..
さんによる
コメントを追加
well... its great this thing cant charge through USB... super awesome especially since earlier versions could
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Yes my port is worn out
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You have to have a external charger ... try the efest pro c4 charger
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I just got the same charger thru the mail yesterday, now my alien works perfectly !
さんによる
コメントを追加
Omg my nice new ecigs' port just got screwed up more since I fiddled about with it with my pocket knife now I'm stuck with vuse wtf I have to get to shop tomorrow.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I ran into this too, but most everyone above is right on the money. It technically can charge through the port and is even advertied for it, but they all eventually fry. Using an external battery charger should fix most of what you guys are working on. Seems stupid to include a port like that with no warning. I have a nitecore charger and no complaints so far, hope this helps
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I also have the 220 watt smok alien I didn't know til reading this the port is firmware only I have the Dogi charger d2 the USB port was only charging one battery this digi charger showede one battery was full the second one was near dead (was on ly charging up to about 55℅ will definitely be using this from now on just now thinking how to keep it flowing so I can cape without a great lapse in time.. Aliens suck lol
さんによる
コメントを追加
I just purchased a Smok X-priv. Day one it charged fine of the usb and my computer. The next day when the batteries were drained, I plugged it in and nothing. It wouldn’t charge. Found this site, and upon reading figures I’d have to buy an external charger. Then I tried my iPhone charger, still it wouldn’t charge. I then pulled the batteries, and without turning the MOD on. I again plugged it into the iPhone charger, and it started charging. I have charged it like this twice now. Letting it charge over night. Hope this helps someone else.
Dave Los Angeles
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Have always purchased another higher wattage 2port charger that's similar to my cellphones, to bring to work & I've had a couple charging smok vapes issues in last 4-5 years....& when I moved the USB corded part to the other charger insert, Smok started charging instantly & I noticed plug outlet turned from blue to green.... & new batteries were put in & I did try to swap batt. Spots earlier... Hoping this will fix previous batteries also... Love this forum & everyone taking time offer solutions. (tired of spending so much money on some vapes)...
さんによる
コメントを追加
Ive tried buying brand new batteries and a brand new charger …. Waste of time and money .. And the dumb a$$3$ at the vape stores didnt know what was wrong… they just wanted to make a quick buck!!! Wish i would have seen this i could have saved ALOT of money…. G-whiz batman i feel duped!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Take the screen protector on the LCD for some reason that protects the screen but it causes the problem for charging and secondly if it don’t work after that get electrical contact cleaner and a toothbrush and clean the USB charging port I’ve done that and it fixed
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Get electrical contact cleaner and a toothbrush and clean the charging port job done works for me
さんによる
コメントを追加
It wont charge and it wont turn on or the light wont turn on
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sonya Gomez さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 25
過去 30 日: 107
今までの合計 197,740
