メインコンテンツにスキップ
The ZTE ZMax Pro is identified by its black color, rear fingerprint sensor and its model name, Z981, which can be found under the rear case.
133回答 すべてを表示
My phone screen froze and I reset but wont turn back on
My phone screen froze and i reset but wont turn back on, its a ZTE zmax pro i was watching a youtube video and it was charging, around 70% i tried pulling down the notifications but that wouldnt work either would any buttons so i held power button down and it turned off now it wont turn on. ive connected it to my pc where i get an error that it is not recgonzied and has malfunctioned when i plug it in the home button does not light up, no combo of power and other buttons will turn it on, i think thats everything but ask if you need anything else
EDIT i was holding down the power button while plugged into my computer and my phone vibrated and a driver call ZTE diagnostic tool installed
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Reset your phone to have a try.
Notice: reset your phone will lose your data.
1. Press and hold the Volume Up and Power buttons until the ZTE logo screen appears, then release.
2.Press the Volume down button to highlight wipe data/factory reset.
3.Press the Power button to select.
4.Press the Volume down button repeatedly until Yes -- delete all user data is highlighted.
5.Press the Power button to select.
6.Wait as the device resets.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Unfortunately I had to to and it did not turn in to anything, and 5 weeks after order a warrrenty replacement I got the new one
さんによる
This is what I need to do but i can't shut my phone off..what should I do?
さんによる
コメントを追加
回答を追加する
Hopeful frank さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,018
