メインコンテンツにスキップ
PlayStationはSonyの最初のマスマーケット向けゲームコンソールです。
73回答 すべてを表示
How to fix a broken lid sensor?
Hello,
a friend of mine has been playing with the lid sensor (the one attached directly on the motherboard with "DOOR" written near it) and effectively broke it.
Is there any way to bypass the switch and have the console think the lid is always closed?
I've seen plenty of guides for this problem on ps2 slimlines but nothing for the original ps1. What I think is that, after having removed the plastic switch, I can bridge solder together the 4 points of contact on the motherboard and that should be it.
Anybody knows for sure? If that's the case which point to I connect to wich? Is it top to bottom? Any particular wire I sure use?
Keep in mind I' new to repairing, but I do have the soldering equipment needed.
If needed I do have a photo of how the motherboard looks now where the switch should be.
Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Tape it down. There are plenty of mods on google
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
What mods are you referencing? A link maybe?
さんによる
Google "Lid Sensor Mod PSX" it is all over. It tricks it to think it is closed
さんによる
コメントを追加
回答を追加する
Nicolo Cichero さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 17
今までの合計 1,315
