メインコンテンツにスキップ
Motorolaの最新モデルは2015年7月に発表されました。Quad HD付き1440 x 2560解像度をもつ5.7インチ IPS TFT LCDスクリーンには21メガピクセルのカメラが搭載されています。モデル番号はXT1570、XT1579、XT1575とXT1578です。
Battery charging issues. Recognizes it but doesn't charge.
Alright, I've posted a similar question, but that one got lost in the abyss that is tech problems.
Alright, so a few months ago i dropped my moto x and the screen shattered. I got all the parts, fixed it, and the screen is functioning like normal. The main problem is that the battery will drain extremely quickly, and the phone will not charge. The phone recognizes the cord as plugged in, but the battery menu says not charging. I have tried two phone chargers, both do not work. I have cleared cache, soft reset, and still nothing. The front flash is also missing, which i was thinking might cause the battery to discharge quickly. I have already replaced the battery, and it still has the same problem. I am beginning to think that it might be a charger port problem, or maybe even a problem with the logic board. (maybe even flash? who knows?)
Also if anyone has a good suggestion in how to glue the screen to the frame of the phone that would be great thanks. (1mm 2 sided tape is not doing the job)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
Did you find a solution? I'm facing the same problem! Thanks
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Sorry no, I've brought my phone to a store and they said they couldn't fix it. Even if it was a problem with the logic board, I don't have the tools to fix it.
さんによる
Thank you for the answer!
さんによる
コメントを追加
I have the same problem too, when i tried to get fixed in service center, its too expensive. So if you guys have any solution, post it here.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
H4N2 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 705
