メインコンテンツにスキップ
Googleの自社名義で発売されたAndroidスマートフォンの修理ガイド、サポート、分解情報など。
1229回答 すべてを表示
Touch doesn't work after screen replacement Google Nexus 5
I had a cracked screen and I replaced it with a new screen. It powers and I can see the notifications and other aspects. But the touch worked for few minutes and has stopped working now. I tried reassemble the screen again but it was not of any use.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Check that there is no damage to the pins on the screen and daughterboard connectors as they could have been damaged by the repair. If they have been you will need to replace either the screen or the daughterboard depending on which is damaged.
Otherwise it is probably a faulty screen, you'll need to get a new one to test.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sun さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 134
