No tail lights or dash lights.
I have a 1996 Nissan Pulsar Sedan that keeps blowing a fuse when I switch on the parkers.I had to replace a couple of bulbs,I've visually checked the wiring,checked for dirt or moisture in all the light sockets and pulled out the dimmer switch,but can't seem to pin point the problem.I cant see any wiring that is loose or contacting.does this model have a relay switch that may cause an issue.The car has very,very low mileage so everything is in immaculate condition.Just this nuisance problem.
この質問は役に立ちましたか?
5 件のコメント
You said that a fuse keeps blowing, thus meaning a short. Was there any work done in the car before this occurred? And when and how did it occur in the first place?
Cameron さんによる
No mechanical work has been done on the car.We did wash the car the same day that we noticed it had the problem.It may sound quirky,but a spider has taken up residence behind the grill and we found a web there.would a spider web cause a short ???.Everything else on the car seems to be fine.All lights and horn,other than the tail lights,number plate lights and dash lights.
Chris Day さんによる
Carlos said what i was going too but it wasnt working. If it blows, remove everything. if it still does, then there is an issue. The spider isnt an issue.
Cameron さんによる
The problem was pinpointed to the indicator stalk which has the parker and headlight switch on the end of it.thanks guys for your help.It was worth going through the whole procedure though,just to make sure.
Chris Day さんによる
Car was fixed temporarily.replaced faulty indicator stalk to resolve park light issue,but the same issue has returned,blowing the fuse,leaving me with no parkers or dash lights,as well as now the car won't turn over even though the battery is fully charged.all I get is a single click noise under the dash.??????????
Chris Day さんによる
