メインコンテンツにスキップ
Repair guides and support for motorcycles manufactured by Yamaha Motor Company.
75回答 すべてを表示
2013 V-Star 650 engine stall at engaging gears
With the side bar up and the clutch lever pulled the engine stalls when You engage the gears. It started after an oil change where I used Valvoline durablend 4T semi synthetic oil for motorcycle . I suspect a malfunctioning side bar security switch but not sure.
The motorcycle has only 48 miles run, almost new.
Could it be a clutch malfunction? I already adjust the clutch cable.
I brought the motorcycle from USA to Belgium.
Please, some idea will be very welcome.
Regards
Hector Alfonso
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
@hmalfonso the model on the bike itself, is it a XVS650?
さんによる
Is your problem solved?
さんによる
コメントを追加
2件の回答
選択されたソリューション
@hmalfonso could be that this is caused by a bad side stand switch. Should be easy to figure out with a multimeter. Location of the switch is marker 19 on the diagram
Here is how to test your switches for continuity etc.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
最も参考になった回答
Im not completely sure on this as to if Yamaha ever had this but over the years Ive had bikes that had a level sensor so the bike can't be put in gear if the bike was leaned to far to one side. sort of a backup for the kick switch . Ive also had problems with the kick switch if the spring doesn't hold the kick all the way up . If the kick switch was malfunctioning would it even let the bike be started ? I would defiantly check that the switch is adjusted to make contact correctly when up. If you don't have a double kick then you'll need a friend to help with this to hold the bike up. Hope this helps a fellow rider
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
回答を追加する
Hector Alfonso さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 20
今までの合計 3,004
