Why can't I get in my rca tablet?
I can't swipe to get in to it, I don't have locks apps I really need some help. If u know anything please let me know. I don't want to buy anything but if I have to i will.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @pokmon ,
It seems as though the digitizer (touchscreen) may have a loose connection or is faulty.
To gain access to the tablet try connecting a USB mouse via an appropriate OTG (On the Go) adapter cable.
By clicking and holding the mouse buttons etc, you should be able to navigate through the tablet.
You can also try connecting a USB keyboard the same way (after you have got in using a mouse) if you need to type anything (obviously you have to remove the mouse and replace with the keyboard) Be aware that for some reason not all USB keyboards will work this way.
Be aware that the tablet's battery will discharge quicker because it is supplying power to the mouse.
Here is a link to a supplier. It is not a recommendation to use them, it is shown to give an idea of the price. Search online for RCT6378W2 OTG cable for other suppliers that may suit you better.
Here is a link to a video which shows how to replace the digitizer.
Here is a link to a supplier of the part. It is not a recommendation to use them, it is shown to give an idea of the price. Search online for RCT6378W2 OTG digitizer for other suppliers that may suit you better.
Before you decide to buy the digitizer, try pressing the reset button on the back of the tablet to see if this restores the digitizer function.
Make sure that if you have accessed the tablet with the mouse that you have saved all your data as a reset might erase it and restore the tablet to a factory default condition (not sure of this but be aware of the possibility that it may)
Hopefully this is of some help
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 5
今までの合計 242
1件のコメント
Didn't help sorry thxs anyway
JaydenGill さんによる
