メインコンテンツにスキップ
Xiaomiスマートフォンの修理ガイドです。
1689回答 すべてを表示
[HELP!] My phone just keeps buzzing few times and then its dead
So, few days ago, I was sitting in a hot thub and I forgot to take my phone off my pocket. I think it was in the water for at least 20 seconds, and unfortunately I was too panic and tried to turn my phone on, at first, it's just show an error screen, like some error list or so, after then, I tried to turn it on again, it only gave me a lit-black screen with shades of water behind the screen, and it's unresponsive.
After I went home, I took everything apart, and I gave my phone some alcohol bathe, and put the battery under the sun, and then whenever I charged it, it only shows lit-black screen, but this time, there was no shade of water, and it shows some respond to charger - as it's vibrating-, and the notification light also turned on as it's charged, but then it's buzzing again and dead, it keeps happening everytime I plug it into the charger.
My only problem is, it has 4000+ pictures that I haven't backed up yet from my travel around the world and I'm just so sad about it. Is there any way that I can fix my phone or atleast save the datas?
My phone is Xiaomi Redmi 3s fyi.
I'll appreciate your helps! Thank you so much
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Muhammad Rizqi thank you for cleaning it properly with alcohol. At least you did not use Rice. As we all know on here, rice does not work. You did not tell us if you removed all EMI shields from your circuit board to clean under those as well. If you have done that you must replace the battery. It is not enough to dry it. Lithium as well as the circuitry inside the battery does not tolerate water. Replace your battery and then try again.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
just put in rice for 3-6 hr and then get a paper towel and dry it
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Sophie Enberg, it has long been established on here that using rice does not work. Check sites like thishttp://www.riceisfordinner.com/ to see and understand why. Rice may at best remove some superficial moisture. It will not clean your phone of elements left behind by the water. Those will lead to corrosion and ultimately will cause a short circuit.
さんによる
コメントを追加
回答を追加する
Muhammad Rizqi さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 534
