メインコンテンツにスキップ
A mobile workstation wtih a 15.6" display manufactured by HP.
1回答 すべてを表示
keyboard typing wrong letters
My keyboard is typing incorrect letters in some cases. Also the trackpad is not working. However in Windows 7 device manager, there are no errors being shown. I did open the laptop to change to a M.2 drive. I may have hit something by accident. Perhaps a ribbon or cable is out. I looked at the maintenance and service guide for answers. They suggest that a keyboard flex cable may have come loose or is not lined up properly. There is no good picture of this in the service guide. Can someone help me? Is there something else that could be wrong? I played with the shift, ctrl, alt, etc. keys and that made no difference.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
This may help with the ribbon cable connector it show a clear video of a ribbon cable being disconnected and then reconnected .https://www.youtube.com/watch?v=C9PwK9eG...
Often when you remove them you don't get them in far enough and that can throw off the keyboard . Hope this helps
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
Here is a disassembly video. I think this is the same as your laptop.
https://www.youtube.com/watch?v=b-rzoUYD...
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Unfortunately the video doesn't go into great detail. It just points out the basics and does not cover keyboard and trackpad.
Also the video shows what appears to be the same as mine, but the grill on the bottom is completely different. It's very close though...It is a Zbook G3.
さんによる
コメントを追加
回答を追加する
Paul Jones さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 1,179
