メインコンテンツにスキップ
Introduced on August 23rd, 2007, the Nikon D300 is a 12.3 megapixel semi-professional DX format digital single lens reflex camera produced by Nikon Corporation.
17回答 すべてを表示
won't turn on through battery grip
nikon d300 won't power up from battery grip without battery grip works ok
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
  • Always check the battery first; it is the most common culprit with a dead camera. Is the battery charged? Is the battery inserted correctly? Are the battery's metal connectors clean? (If not, you can use a soft cloth to remove any grime from the connectors.) Are there any particles or foreign objects in the battery compartment that could prevent a good connection?
  • ith most Nikon point and shoot cameras, you can press a "monitor" button or a "display" button that will place the shooting settings and information on the display screen. Repeatedly pressing this button will cause different information to appear on the screen or will remove all shooting data from the screen.
  • Check more solutions from Nikon d300 Manual.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
John Hayes さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 403
