メインコンテンツにスキップ
Guides for popcorn machine and popcorn popper repair.
16回答 すべてを表示
Popcorn not popping out of kettle
When the corn starts popping, some of it comes out of the kettle but then it seems that the unit that spins on the bottom stops and the popcorn continues to pop but is trapped in the kettle. I have to turn the unit off and use a knife to "pry" the popcorn out.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
5 件のコメント
@carlie2017 what make and model is your popcorn machine. You checked the agitator and stirrer? what have you checked?
さんによる
Could you take some pictures to show us what you mean?
さんによる
I Great Northern could not popping all kettle. It left over haft the kettle inthe pot? any one know how to fix
さんによる
Can you replace the thermostat in a ccp399 Popcorn cart? Brand new Used for 8 pops and now will not pop?
さんによる
the possibility of the connector to the stem is not tight. when the corn seed begin to explode and have a load on the stem. the shaft does not rotate according to the motor. or your motor has broken. when the motor overheats it causes the motor to stop abruptly and spin again when it has cooled down.
さんによる
コメントを追加
2件の回答
選択されたソリューション
@carlie2017 since you did not tell us what the make and model of your popcorn maker is, we can only provide you with a generic answer. This sounds like an agitator issue:
Is the agitator working?
YES!
A. Check to be certain the agitator blade and weight are free to move on the bottom of the shaft.
B. Check to be certain the stirrer blade is on the bottom of the pan and is stirring the corn.
C. Were the correct amounts of corn and oil used? See Operation Section for correct amounts.
D. Temperature set too high? - adjust temperature.
NO!
A. Check motor connections - loose wire.
B. Motor bad - replace.
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
I have the same issue. This is a new machine I got at Christmas. It worked great for the first couple times. Now the popcorn keeps getting stuck. I have cleaned it multiple times but it’s still happening. Model#BC-2975CJ
さんによる
コメントを追加
depending on the model...many kettle stirrers have the ability to slide upward when they encounter a jam...at which point they no longer stir. it is a safety mechanism to prevent ruining your motor or damaging the stirrer. many of them also have a heavy nut that slides over the top to hold them in place. ensure the kettle does not have carbon buildup or other crud that is keeping the stirrer from turning freely. and ensure that the stirrer is functioning properly. if you need to clean your kettle an easy and safe way is with hydrogen peroxide and baking soda mixture. place in kettle and turn on heat and stirrer. place rags/towels in the bottom of your machine as it will bubble up. after a few minutes turn off the heat, unplug and scrub gently any remaining buildup with a non-scratch cloth. rinse and clean with warm water on a cloth. it will look like new without harming your finish...and easy food safe cleanup. also make sure your flapper doors are working freely to allow the popcorn to come out of the kettle. careful using a knife as you do not want to scratch your kettle.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Mary さん、ありがとうございました!
統計データ:
過去 24時間: 10
過去 7 日: 72
過去 30 日: 286
今までの合計 23,907
