メインコンテンツにスキップ
2009年に発売されたエントリーレベルのフォトスマートプリンターです。プリントヘッドが使い捨てタイプのHP Tri-Colorインクカートリッジを使用します。
My inkjet isn't being an inkjet
Ok so I needed an inkjet printer to print my designs onto some iron on designs and when I printed it all out and went to iron it on it wouldn't transfer over. My colleague said it was because it wasn't printed using an inkjet printer. My printer says its ink type is inkjet. Why is it not working?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi,
Have you selected the iron on transfer option in your printer's preferences area and are you using the correct print media?
Here's how to do it. This is taken from the User Guide for your printer
To reverse an image for iron-on transfers
1. On the File menu in your software application, click Print.
2. Make sure the product is the selected printer.
3. Click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties, Options, Printer Setup, Printer, or Preferences.
4. Click the Features tab.
5. In the Paper Type drop-down list, click More, and then select HP Iron-on Transfer from the list.
6. If the selected size is not what you want, click an appropriate size in the Size list.
7. Click the Advanced tab.
8. In the Features area, select the Mirror Image check box.
9. Click OK, and then click Print or OK in the Print dialog box.
Hopefully this is of some help
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Ren Yi Get it さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 133
