Fetch TV Mighty PVR runs very hot
I would love to see a teardown of more PVR's, specifically the Fetch TV Mighty. This unit is so compact that I'm not even sure where to start. Mostly I want open it up, and then improve the cooling.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
Is it overheating at all and causing problems?
How old is the device?
If it still is within the warranty period and even if it is not (hard to find any information regarding warranty of pvr on the Fetch TV website) I recommend that you contact Fetch TV and ask if the excessive heat is a 'normal condition' and if not can you get a replacement.
このアンサーは役に立ちましたか?
Hey thanks for the response. I haven't asked the OEM if it's normal but I did call the store, and they said it is (not sure if they're just saying that). So yeah next stop is Fetch themselves.
But my request still stands. I think we can demystify the PVR by if there are teardowns and specs.
Hi,
Possibly, but it is always better not to void the warranty in case it is due to poor design ;-)
24 month manufacturer warranty mine has
I just want to know how to open it. It is a hard puzzle to work out.
このアンサーは役に立ちましたか?
https://www.youtube.com/watch?v=zhYVwWQN... ... worked for me :-)
過去 24時間: 2
過去 7 日: 5
過去 30 日: 41
今までの合計 1,625
1件のコメント
I have been having many problems with my fetch mighty and also noticed it does seem to run really hot and have reception issues with it and fetch support has told me it requires a stronger signal than normal to operate. When the signal isn’t being received properly other than it being jittery and annoying to try and watch that’s when it seems to have trouble processing anything operations such as when pressing button a on the remote it’s like it freezes or hangs. I have tried removing the antenna when that happens and after 30 seconds or so controls work again so I can do a reset which sometimes helps reception. Already had the box replaced once and the new one has issues again but so far is working better than the last one. The last one was fine when it was new
Christian Marshall さんによる
