Locked out of desktop
Locked out can't remember I'd or password
Hello Nate! The only way to bypass your Windows password (that I know of) is by using a tool called "Konboot". You need to buy a license if your Windows version is new than XP. The program is installed on a USB stick. Once it is installed, you boot from the USB stick and Konboot will do its magic and take you straight to Windows where you can put anything in the password field and it will work.
If you do not mind losing your data, you could try doing a system recovery.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 134
I cannot get into the system. I've tried f2. F12. Delete. On start up. Won't let me into the bios
Nicole A Thomas さんによる
